Pure MicroPython Display Driver for ESP32
Building a pure MicroPython ILI9341 display driver for ESP32 using DMA and double buffering, with performance benchmarks and insights.
Amir GonnenAmir Gonnen21 min read
I created a Pure MicroPython display driver for ILI9341 on ESP32. Here it is.
"Pure MicroPython", in this sense, means that all logic is implemented in MicroPython, and uses the standard API for LVGL and ESP-SDK libraries.
LVGL by itself is very portable and can be used on many hardware devices and architectures. However, it requires a display driver, specific to the hardware it runs on. So if you use ESP32 and you want to display a nice GUI on your ILI9341 display, you need an "LVGL-ESP32-ILI9341" display driver.
LVGL project already provides C implementation of that driver, and there's even a MicroPython API for it, but I wanted to create a Pure MicroPython implementation of the same driver.
This driver uses DMA and double buffering to achieve high performance. At the bottom of this post you can find performance statistics and conclusions about using MicroPython for a display driver.
This display driver can run in two modes:
  • Pure MicroPython mode - all the display driver logic is done in MicroPython.
  • Hybrid mode - Setup and initialization are done in MicroPython, but the critical path (flush and ISR functions) is implemented in C.
Why?#
Why would I re-write a module in MicroPython that is already written in C?
For three reasons:
  • It's a showcase for many interesting/advanced features related to MicroPython Binding
  • I wanted to see how it would perform, compared to the C driver
  • It makes possible to dynamically load drivers
Here are some interesting features that are used in the Pure MicroPython Display Driver:
MicroPython API to any C library#
The driver needs to interact with LVGL and ESP-IDF. LVGL provides C API for registering a driver, and ESP-IDF provides C API for interacting with ESP32 hardware, access GPIO, and SPI devices for example.
Traditionally, when you want to expose a C API to MicroPython, you have to add a native MicroPython Module. This means wrapping every C API function with special code to convert parameters, and later register it in MicroPython. For a few functions, that's not so bad, but for a large library this becomes tedious to create and maintain.
Another thing is the issue of structs and pointers. C uses them a lot, but MicroPython doesn't really have a notion of pointers and structs, so they need to be handled in a special way when creating the API manually. LVGL is a large C library, and creating an lvgl MicroPython module manually was out of the question.
Instead, I've created the MicroPython LVGL Binding, which is at its core a Python script that parses C header files and generates MicroPython module automatically from them. The automatically generated MicroPython module not only handles function calls. It also provides API to structs, enums, callbacks, etc.
I was working on this for a while, then I realized MicroPython Binding could be used in a wider scope.
Why use it only for LVGL? What about other libraries?
In this blog post I'm going to show you how MicroPython Bindings was used to create a MicroPython API for ESP-IDF, in addition to LVGL MicroPython API!
By the way, I also used it to provide an API for lodepng, which is a library for encoding and decoding PNG files. But this is out of the scope of this blog post. If you are interested in that, have a look at this example script.
Using Pointers in MicroPython#
C API usually relies heavily on pointers. Some C functions allocate or consume buffers, which are passed as pointers. Many functions receive a pointer and update the value it points at, instead of returning a value.
MicroPython, on the other hand, just like Python, doesn't need and doesn't have native pointers as we have in C. In Python (as well as other languages such as JavaScript), an object is accessed by reference. There are no Pointers per-se, no pointer-dereferencing, no pointer-arithmetic, etc.
The MicroPython Binding bridges that gap - it makes it possible to use Pointers in MicroPython. Either pass them to functions, assign them to fields in structs, dereference them, or convert them into MemoryView.
The Pure MicroPython Display Driver uses pointers in several contexts:
  • For allocating DMA-able RAM
  • When sending a DMA transaction
  • On ESP-IDF functions that receive pointers.
Using Callbacks from C to MicroPython#
When we want to register a C callback we pass a function pointer. But what if we want the callback to call MicroPython code?
The Pure MicroPython Display Driver code illustrates several callback use-cases:
  • Registering C function as a callback (both caller and callee are defined in C, but the callback registration is performed by MicroPython code).
  • Registering MicroPython data to pass to a C callback function.
  • Registering MicroPython function as a callback on LVGL API, which supports MicroPython callbacks. (Caller is defined in C while the callee is defined in MicroPython).
  • Registering MicroPython function as a callback on ESP-IDF API, which doesn't support MicroPython callbacks, therefore requires special handling.
Interrupt handling in MicroPython#
MicroPython allows you to write an ISR in MicroPython and handle interrupts without writing a dedicated function for it in C. This involves several limitation and considerations.
The Pure MicroPython Display Driver implements a DMA completion interrupt, to signal LVGL that the display "flush" was completed.
How?#
Below are snippets from ili9341.py, espidf.h, espidf.c to illustrate and explain different features in the Pure MicroPython Driver.
Auto generated C API#
import espidf as esp
import lvgl as lv
python
These two modules are automatically generated by the MicroPython Binding script.
  • lvgl is generated from lvgl.h and provides API to the entire LVGL library.
  • espidf is generated from espidf.h to provide API to some of the ESP-IDF.
Here is the most important part from espidf.h:
// The following includes are the source of the esp-idf micropython module.
// All included files are API we want to include in the module
#include "driver/gpio.h"
#include "driver/spi_master.h"
#include "esp_heap_caps.h"
#include "esp_log.h"
#include "esp_clk.h"
So we are not providing a full ESP-IDF API. That would be huge. At this point, only an API for functions and structs in these include files are added.
So what is the rest of the content of espidf.h?
  • A few include guard defines (such as #define INC_FREERTOS_H). This is a trick to prevent an inner include to be applied. While we are interested in the included files above, these files in turn include addition headers we are not interested in (we don't want the entire FreeRTOS API!). This trick would exclude them.
  • A few helper functions we want to include in ESP-IDF API although they are not really part of it. For example, get_ccount to measure CPU cycles.
  • A few additional enums. Enums will become part of the API while defines won't, so I added what I thought would be useful.
  • ILI9341 hybrid mode functions (for example ili9341_flush). These functions are optional, the Pure MicroPython display driver doesn't require them. But when the hybrid mode is enabled, these functions are used for the critical path and the driver performance increase significantly. See more details on the "Performance" section below.
When building the ESP32 port of the MicroPython project, the Makefile contains rules to generate these modules. For example:
#esp-idf generated module
ESPIDFMOD_SOURCE = $(TOP)/lib/lv_bindings/driver/esp32/espidf.h
ALL_ESPIDFMOD_SRC = $(shell find $(subst -I,,$(INC_ESPCOMP)) -type f) $(ESPIDFMOD_SOURCE) $(SDKCONFIG_H)
ESPIDFMOD_MODULE = $(BUILD)/espidfmod/mp_espidf.c
ESPIDFMOD_PP = $(BUILD)/espidfmod/mp_espidf.pp.c
CFLAGS_MOD += $(ESPIDFMOD_CFLAGS) -Wno-deprecated-declarations
$(ESPIDFMOD_MODULE): $(ALL_ESPIDFMOD_SRC) $(LVGL_BINDING_DIR)/gen/gen_mpy.py
    $(ECHO) "ESPIDFMOD-GEN $@"
    $(Q)mkdir -p $(dir $@)
    $(Q)$(CPP) $(ESPIDFMOD_CFLAGS) -DPYCPARSER -I $(LVGL_BINDING_DIR)/pycparser/utils/fake_libc_include $(INC) $(INC_ESPCOMP) $(ESPIDFMOD_SOURCE) > $(ESPIDFMOD_PP)
    $(Q)$(PYTHON) $(LVGL_BINDING_DIR)/gen/gen_mpy.py -M espidf -E $(ESPIDFMOD_PP) $(ESPIDFMOD_SOURCE) > $@
makefile
This does essentially two important things:
  • Preprocess espidf.h by the C preprocessor. This applies all nested "includes" and produces a single preprocessed file with the entire API we want to generate.
  • Run gen_mpy.py on the preprocessed file. This is where the magic happens, and C functions and structs are transformed into a MicroPython module. The output of this step is mp_espidf.c, which is the implementation of the ESP-IDF MicroPython module.
Eventually, the ESP-IDF MicroPython module is compiled, linked and referenced in the project, making it available for import by MicroPython scripts.
So how does the generated API look like?
MicroPython v1.11-194-g29bbfd8-dirty on 2019-07-22; ESP32 module with ESP32
Type "help()" for more information.
>>> help(esp)
object <module 'espidf'> is of type module
  __name__ -- espidf
  get_ccount -- <function>
  esp_err_to_name -- <function>
  esp_err_to_name_r -- <function>
  _esp_error_check_failed -- <function>
  _esp_error_check_failed_without_abort -- <function>
  gpio_init -- <function>
  gpio_output_set -- <function>
  gpio_output_set_high -- <function>
  gpio_input_get -- <function>
  gpio_input_get_high -- <function>
  gpio_intr_handler_register -- <function>
  gpio_intr_pending -- <function>
  gpio_intr_pending_high -- <function>
  gpio_intr_ack -- <function>
  gpio_intr_ack_high -- <function>
  gpio_pin_wakeup_enable -- <function>
  gpio_pin_wakeup_disable -- <function>
  gpio_matrix_in -- <function>
  gpio_matrix_out -- <function>
  gpio_pad_select_gpio -- <function>
  gpio_pad_set_drv -- <function>
  gpio_pad_pullup -- <function>
  gpio_pad_pulldown -- <function>
  gpio_pad_unhold -- <function>
  gpio_pad_hold -- <function>
  [... many more functions ...]
It can be, of course, larger or smaller depending on what's in the H file that is fed into the MicroPython Binding script.
It's easy to include too many functions/structs in an API. That's because a public C API might include private headers, which are not usually used by the user. But the script doesn't know that and takes every function/struct/enum from the preprocessed file.
To overcome this you can either:
  • Disable some of the includes (by defining some include guard, for example)
  • Or write a separate C API header file that delegates the calls to the real API. (the calls would be on the C file which is not considered by the script). This requires more work but has the advantage of letting you control the API and make it more "python-friendly".
Another thing to take into account is that C macros are not handled by the Binding Script, because it analyzes the preprocessed file. A workaround for this is to wrap the macros in an enum, which is converted to MicroPython.
An example from espidf.h:
// Useful constants
enum{
    CAP_DMA = MALLOC_CAP_DMA,
    CAP_INTERNAL = MALLOC_CAP_INTERNAL,
    CAP_SPIRAM = MALLOC_CAP_SPIRAM
This would generate a MicroPython object esp.CAP which has a field for each enum member. For example here we use esp.CAP.DMA:
trans_buffer = esp.heap_caps_malloc(trans_buffer_len, esp.CAP.DMA)
python
A few footnotes:
  • Ideally, the process of adding a new API to MicroPython should be automated too, such that converting a C library to MicroPython would be even easier and won't require messing with Makefile scripts, which is never pleasant.
  • Some naming should be changed. Perhaps gen_mpy.py should be called gen_upy.py etc.
ILI9341 python class#
class ili9341:
    width = const(240)
    height = const(320)
    disp_buf = lv.disp_buf_t()
    disp_drv = lv.disp_drv_t()
    def __init__(self, miso=5, mosi=18, clk=19, cs=13, dc=12, rst=4, backlight=2, spihost=esp.enum.HSPI_HOST, mhz=40, factor=4, hybrid=True):
        # Make sure Micropython was built such that color won't require processing before DMA
        if lv.color_t.SIZE != 2:
            raise RuntimeError('ili9341 micropython driver requires defining LV_COLOR_DEPTH=16')
        if not hasattr(lv.color_t().ch, 'green_l'):
            raise RuntimeError('ili9341 micropython driver requires defining LV_COLOR_16_SWAP=1')
python
When declaring the class, the first thing we check that color mode is correct. LVGL can be configured to use different color modes, starting from 1 bit monochrome up to 32 bit RGB with alpha channel. For the Pure Python display driver to work correctly, LVGL color mode must match ILI9341 color mode, 16-bit RGB565. If we didn't do that we would have to translate every pixel to RGB565, and this is a lot of work for a display driver.
So this is achieved by building lv_micropython with this parameter:
LV_CFLAGS="-DLV_COLOR_DEPTH=16 -DLV_COLOR_16_SWAP=1"
Using Pointers#
If we just pass pointers around, this is very easy. Each pointer is wrapped in a MicroPython "Blob" object which is convertible to pointer between API functions, even if they belong to different libraries. For example:
self.buf1 = esp.heap_caps_malloc(self.buf_size, esp.CAP.DMA)
self.buf2 = esp.heap_caps_malloc(self.buf_size, esp.CAP.DMA)
lv.disp_buf_init(self.disp_buf, self.buf1, self.buf2, self.buf_size // lv.color_t.SIZE)
python
Here we allocate two DMA capable buffers using ESP-IDF API function, and pass them to LVGL function that initializes the display buffers.
But what if we want to read or write to the data the pointer points at, in MicroPython? Each "Blob" has a __dereference__ functions which allows you to convert it to a MemoryView.
trans_buffer_len = const(16)
def send_data(self, data):
    esp.gpio_set_level(self.dc, 1)	   # Data mode
    if len(data) > self.trans_buffer_len: raise RuntimeError('Data too long, please use DMA!')
    trans_data = self.trans_buffer.__dereference__(len(data))
    trans_data[:] = data[:]
    self.spi_send(trans_data)
python
send_data function receives data which is an array of bytes, and sends it by calling spi_send. But spi_send expects to receive a DMA-able buffer! We need to copy data into a DMA-able memory. So we prepare trans_buffer which is a pointer to DMA-able memory, and copy data into it. To do that, we dereference trans_buffer (self.trans_buffer.__dereference__(len(data))), and copy the data into it (trans_data[:] = data[:])
Another case is using a pointer as a function output. What if we have an API function that receives a pointer, and updates the data it points at?
For example:
esp_err_t spi_bus_add_device(spi_host_device_t host, const spi_device_interface_config_t *dev_config, spi_device_handle_t *handle);
On this function, dev_config is an input. That's easy, just create a struct, fill it up, and pass it over.
For example:
devcfg = esp.spi_device_interface_config_t({
    "clock_speed_hz": self.mhz*1000*1000,   # Clock out at DISP_SPI_MHZ MHz
    "mode": 0,                              # SPI mode 0
    "spics_io_num": self.cs,                # CS pin
    "queue_size": 2,
    "flags": esp.ESP.HALF_DUPLEX,
    "duty_cycle_pos": 128,
ret = esp.spi_bus_add_device(self.spihost, devcfg, ptr_to_spi)
python
Here, by the way, we used a dict to initialize a struct by passing it to esp.spi_device_interface_config_t constructor. This is only possible on struct initialization. On other cases, fields can be accessed as object attributes. For example devcfg.pre_cb = None would assign NULL to pre_cb field of devcfg struct.
But what about the last parameter of spi_bus_add_device? spi_device_handle_t *handle is an output. We need to create a pointer, pass it over to spi_bus_add_device and dereference it. The trick is to use a struct called C_Pointer, like this:
ptr_to_spi = esp.C_Pointer()
if ret != 0: raise RuntimeError("Failed adding SPI device")
self.spi = ptr_to_spi.ptr_val
python
In this case we pass ptr_to_spi of type C_Pointer to the function, and later access ptr_to_spi.ptr_val to dereference it and extract the output value written by spi_bus_add_device. So what's this C_Pointer is about? It's a simple helper union that looks like this:
typedef union {
    void *ptr_val;
    int int_val;
    unsigned int uint_val;
    const char *str_val;
} C_Pointer;
So we create an instance of C_Pointer, pass it over to a function that writes something into it (either a string, an int, or another pointer like our case). After the function updated it, it's very easy to extract the relevant data from it, by accessing the right union field.
Using Callbacks#
Callbacks on MicroPython C API is a subtle subject. While in C all you need is a function pointer (code only), on MicroPython a callable object is needed (which contains data, not only code). So when we want to register a MicroPython function to be called from C, we need to find a way to record the callable object on C and pass it to the callback.
On LVGL this is done using the user_data field, that is present on structs where callbacks are used. On other libraries that do not follow this convention, you might need to wrap the callback registration/invocation and find another way to pass the callable object.
    self.disp_drv.user_data = {'dc': self.dc, 'spi': self.spi}
    self.disp_drv.flush_cb = esp.ili9341_flush if self.hybrid and hasattr(esp, 'ili9341_flush') else self.flush
    self.disp_drv.monitor_cb = self.monitor
python
Here, the display driver instantiates and fills disp_drv_t struct. This struct describes the display driver. The display driver implements two callbacks: flush_cb and monitor_cb.
In case of flush_cb:
  • if running in hybrid mode, the callback is set to the C implementation of flush (esp.ili9341_flush). This case is simply a pointer assignment.
  • If not running in hybrid mode (but in "pure python" mode), the flush is registered as self.flush function, which is the pure python implementation of flush.
Under the hoods, the assignment to flush_cb saves the callable object self.flush in user_data member of disp_drv, this is automatic and hidden from the user. Later on, I'll show an example of registering callbacks on ESP-IDF, where the callback convention is not followed as it is in LVGL, and the copy of the callable object to user_data does not happen automatically.
Consider the case of hybrid mode. In this case we register a C function esp.ili9341_flush to flush_cb. When LVGL wants to flush the display data to the display it calls it. esp.ili9341_flush in turn should access the SPI device and DMA the data. However, the SPI device was initialized in MicroPython code - how can esp.ili9341_flush access it?
On LVGL, every callback receives as the first parameter a struct which contains data related to the callback, in our case - lv_disp_drv_t. Every such struct contains a field called user_data, the same field that holds the callable object when registering MicroPython function. We can use it to store our own custom data, in addition to callable objects!
python
esp.ili9341_flush needs the SPI device and DC pin, which were initialized in the MicroPython side, in order to do its work. user_data is a void * member of lv_disp_drv_t. But since it was initialized to a python dict it can be casted back. Let's have a look at it, on ESP32 interactive console after the driver was initialized:
MicroPython v1.11-330-g6f2b2e2-dirty on 2019-07-29; ESP32 module with ESP32
>>> import ili9341
ILI9341 initialization completed
Enable backlight
Double buffer
>>> print(ili9341.disp.disp_drv.user_data.cast())
{'lv_disp_drv_t_flush_cb': <function>, 'lv_disp_drv_t_monitor_cb': <bound_method>, 'dc': 12, 'spi': Blob}
As you can see, user_data dict contains our dc and spi members, as well as the callable objects for flush_cb and monitor_cb.
Now, how can esp.ili9341_flush extract this data from user_data? Let's have a look at it:
void ili9341_flush(void *_disp_drv, const void *_area, void *_color_p)
    // We use disp_drv->user_data to pass data from MP to C
    // The following lines extract dc and spi
    int dc = mp_obj_get_int(mp_obj_dict_get(disp_drv->user_data, MP_OBJ_NEW_QSTR(MP_QSTR_dc)));
    mp_buffer_info_t buffer_info;
    mp_get_buffer_raise(mp_obj_dict_get(disp_drv->user_data, MP_OBJ_NEW_QSTR(MP_QSTR_spi)), &buffer_info, MP_BUFFER_READ);
    spi_device_handle_t *spi_ptr = buffer_info.buf;
dc is read in a straightforward way - get the dict from user_data and convert dc field (it's name is given as a qstr) to int. spi on the other hand, is a pointer. Pointers are saved using buffer protocol, therefore an mp_get_buffer_raise is used to extract it.
So far I've shown you how a callback (either C or MicroPython) is registered to LVGL, which was designed to automatically save the callable object in user_data. But what if the API was not designed that way?
When DMA completes, ESP-IDF calls post_cb function, (in ISR context, but that does not matter for this point). We might want to register a MicroPython function as post_cb, but post_cb doesn't receive a struct with user_data member, so the Binding Script cannot automatically save the callable object there.
Fortunately, post_cb receives a struct with user field that can be used exactly for that! We will use the user field to pass over the callable object, but this time, without using a dict. Instead, user will contain a new object of type spi_transaction_ptr_type that holds information for the callback, such as the post_cb callable object.
DEFINE_PTR_OBJ_TYPE(spi_transaction_ptr_type, MP_QSTR_spi_transaction_ptr_t);
typedef struct{
    mp_ptr_t spi_transaction_ptr;
    mp_obj_t pre_cb;
    mp_obj_t post_cb;
} mp_spi_device_callbacks_t;
void *spi_transaction_set_cb(mp_obj_t pre_cb, mp_obj_t post_cb)
    mp_spi_device_callbacks_t *callbacks = m_new_obj(mp_spi_device_callbacks_t);
    callbacks->spi_transaction_ptr.base.type = &spi_transaction_ptr_type;
    callbacks->pre_cb = pre_cb != mp_const_none? pre_cb: NULL;
    callbacks->post_cb = post_cb != mp_const_none? post_cb: NULL;
    return callbacks;
spi_transaction_set_cb is a C function declared on espidf.h, therefore it will be included in ESP-IDF MicroPython API automatically. It receives two callable objects pre_cb and post_cb, registers them in a spi_transaction_ptr_type object and returns.
The MicroPython code of the display driver calls this function:
def disp_spi_init(self):
    if self.hybrid and hasattr(esp, 'ili9341_post_cb_isr'):
        devcfg.post_cb = esp.ili9341_post_cb_isr
    else:
        devcfg.pre_cb = esp.spi_pre_cb_isr
        devcfg.post_cb = esp.spi_post_cb_isr
    self.spi_callbacks = esp.spi_transaction_set_cb(None, flush_isr)
def spi_send_dma(self, data):
    self.trans.user = self.spi_callbacks
    esp.spi_device_queue_trans(self.spi, self.trans, -1)
python
The init code registers flush_isr callback, and saves the spi_callbacks result (of type spi_transaction_ptr_type). When sending DMA, the transaction user field is set to that spi_callbacks. On pure python mode, the post_cb C callback is set to esp.spi_post_cb_isr, which extracts the callback from the user field:
void spi_post_cb_isr(spi_transaction_t *trans)
    mp_spi_device_callbacks_t *self = (mp_spi_device_callbacks_t*)trans->user;
    if (self) {
        self->spi_transaction_ptr.ptr = trans;
        cb_isr(self->post_cb, MP_OBJ_FROM_PTR(self));
The cb_isr receives post_cb callable MicroPython object, and will call it in ISR context.
Calling MicroPython code in ISR context#
When you want to run MicroPython in ISR context you have two options:
  • Schedule MicroPython function to run when MicroPython core is ready.
  • Run MicroPython immediately - with some limitations.
The easiest thing to do it to schedule MicroPython. This means that MicroPython will not run in ISR context, but shortly after in standard user mode FreeRTOS task context. The drawback is that the function will not run immediately. It will take some time, may require a context switch etc. What if you want to do something right now?
Two options:
  • Write the ISR in C.
  • Run MicroPython immediately - with some limitation.
What limitations are there, to run MicroPython directly in ISR?
MicroPython docs have a chapter discussing exactly this, how to write interrupt handlers in MicroPython. ESP32, apparently, has some additional complications but this is still doable.
In the Pure MicroPython Driver we register flush_isr MicroPython function to be called directly in ISR context when DMA completion post_cb is called, when running in Pure MicroPython mode (non-hybrid)
Test conditions:
  • SPI is configured to 40MHz
  • Sending ~104KB every frame (That's ~70% of the total display area of ILI9341 being refreshed every frame)
  • DMA, Double Buffering with Two non-screen-sized buffers
  • Each display buffer consumes 25% of the display area
  • LVGL configured with LV_COLOR_DEPTH=16 and LV_COLOR_16_SWAP=1, which makes the display buffer compatible with ILI9341, and does not require processing every pixel. Otherwise, every pixel would have to be converted to RGB in the right format.
  • LVGL refreshes large area of the screen every frame, but does not do a lot of work to render it. That's because we are measuring the display driver performance, not lvgl rendering performance, so we don't want lvgl to be the bottleneck in this measurement.
So where, in the time budget, hides LVGL rendering time? Since this driver uses double buffering, two things happen simultaneously: DMA to buffer A and rendering to buffer B! (then on the next frame it switches, DMA to buffer B and rendering to buffer A), that's the idea behind double buffering. So as long as LVGL rendering time ≤ DMA time, rendering time does not affect FPS at all. For the purpose of this test, I kept LVGL rendering time low enough (shorter than DMA time) such that we can ignore it.
Results:
Pure MicroPython Driver#
  • 35ms per frame (28.5FPS)
  • DMA is 20ms out of the 35ms
  • MicroPython code is 15ms out of the 35ms
Hybrid MicroPython Driver#
SPI setup, ILI9341 initialization etc. remain in MicroPython. Only the critical "flush" function and interrupt handling done in C (see ili9341_flush here)
  • 20ms per frame (50FPS)
  • Limiting factor is DMA and ILI9341. From DMA perspective, Higher FPS up to 100FPS may be possible with higher SPI frequency (80MHz), but requires using dedicated IO pins (IOMUX instead of GPIO matrix), therefore not tested. From ILI9341 perspective, running it faster than 10MHz is out of spec, but a common practice. Many people ran it at higher rates up to 40Mhz, and some even up to 80Mhz!
Does it make sense to write a display driver in pure MicroPython? Probably not, at least not the critical paths. It can still be useful to write the setup code in MicroPython (setting up SPI and initializing ILI9341 for example), but paying 15ms every frame only to run MicroPython code that would flush data to the display, feels too much for me.
But there is still hope! MicroPython has a Native Code Emitter and Viper Code Emitter which translate MicroPython code directly to native CPU opcodes! That would boost performance significantly. Unfortunately, these code emitters are not available for ESP32 yet. Let's hope someday they will be.
Amir Gonnen
Amir Gonnen
Community Contributor
Developer and maintainer of the LVGL MicroPython bindings, enabling Python-based UI development on embedded devices.
