Using Dithering for Smooth Images on 16-Bit Displays
Learn how to apply dithering to eliminate color banding on 16-bit displays and achieve smooth gradients without performance loss.
Gabor Kiss-VamosiGabor Kiss-Vamosi5 min read
If you've worked with 16-bit color displays, you've likely encountered ugly color banding in images with smooth gradients. The 65,536 colors available in RGB565 format often aren't enough to represent subtle transitions. Fortunately, dithering solves this problem by creating the illusion of greater color depth through clever pixel manipulation.
What is Dithering?#
Dithering is an image processing technique that gives the appearance of greater color depth by strategically arranging pixels. Both images below use only 256 colors, but the dithered version on the right looks significantly smoother.
8-bit image without dithering showing visible color bands
8-bit (256 colors) image without dithering
8-bit image with dithering showing smooth gradients
8-bit (256 colors) image with dithering - working from the same color palette, the dithered version looks much better
Why Use Dithering on Embedded Systems?#
On embedded systems, 16-bit color depth (RGB565) is extremely common because it requires much less memory and fewer data lines than 24-bit color. For most use cases, there's no noticeable difference in quality. The exception is smooth color gradients, where 16-bit displays simply don't have enough colors to create seamless transitions.
Dithering solves this problem at compile time with zero performance impact at runtime. You convert your images once during development, and they display smoothly on the target hardware.
How Dithering Works in Practice#
The concept is simple: imagine creating gray from only black and white pixels. By alternating black and white pixels, the human eye perceives an average gray color. Use more white pixels for lighter gray, more black for darker gray.
Real dithering algorithms are more sophisticated, tracking quantization errors after placing each pixel and applying various techniques to avoid visual artifacts.
For a deep dive into dithering algorithms, see Image Dithering: Eleven Algorithms and Source Code by Tanner Helland.
Visual Comparison#
Original 24-Bit Image#
Original 24-bit color image with smooth gradients
The original image with 24-bit color depth has smooth color gradients
Original Enlarged#
Enlarged view of 24-bit image showing smooth pixels
Even when enlarged, the gradients remain perfect
16-Bit Without Dithering#
16-bit image showing color banding
Converting to 16-bit color depth creates ugly stripes because there aren't enough colors
16-Bit Without Dithering (Enlarged)#
Enlarged 16-bit image with visible banding artifacts
The color banding stripes are clearly visible when enlarged
16-Bit With Dithering#
16-bit dithered image with smooth appearance
The dithered image at 16-bit color depth looks nearly identical to the original. A few subtle stripes may be visible on close inspection, but it's dramatically better than the non-dithered version
16-Bit With Dithering (Enlarged)#
Enlarged dithered 16-bit image showing noise pattern
The enlarged dithered image shows a slight noise pattern, but no color banding
How to Dither Images for RGB565#
The easiest way to convert your 24-bit images to dithered 16-bit format is using photo editing software. Here are two recommended approaches:
GIMP is a free, cross-platform image editor.
GIMP requires a plugin for RGB565 dithering. Download the plugin from the GIMP registry or use this mirror if the original link is unavailable.
Installation steps:
  1. Copy dither16bit.scm to GIMP's scripts directory (on Linux: /home/user/.gimp-*/scripts)
  2. Copy the four grayscale palette files (*.gpl) to GIMP's palettes directory (on Linux: /home/user/.gimp-*/palettes)
To apply dithering:
Open your image in GIMP and select Image > Mode > Dither to RGB565, then save the result.
Method 2: ImageMagick (Command Line)#
ImageMagick is a powerful command-line image processing tool with support for many dithering algorithms.
To dither an image, run:
Bonus: Black and White Dithering#
For monochrome displays (like high-DPI e-paper or OLED screens), you can create 1-bit dithered images in GIMP:
  1. Open your image
  2. Select Image > Mode > Indexed
  3. Choose Use black and white color palette as the Colormap
  4. Select Floyd-Steinberg as the Color Dithering method
GIMP dialog showing black and white dithering settings
GIMP settings for black and white dithering
Here's a comparison of the results:
Using Dithered Images in LVGL#
Once you have a dithered image, you can use it in LVGL like any other image:
  1. Upload your dithered BMP, JPG, or PNG to the LVGL Online Image Converter
  2. The tool generates a C array from your image
  3. Copy the resulting C file to your project
  4. Display the image using an LVGL image object
Dithering is a simple yet effective technique for achieving smooth gradients on 16-bit displays. By converting your images during development, you eliminate color banding without any runtime performance cost. Whether you're working with RGB565 displays or monochrome screens, dithering can dramatically improve your visual quality.
