PikaScript: Lightweight Python for Microcontrollers with LVGL
Run Python on microcontrollers with just 32 KB flash and 4 KB RAM. PikaScript brings LVGL8 support with MicroPython-compatible APIs and intelligent C bindings.
Lyon LisboaLyon Lisboa5 min read
What is PikaScript?#
PikaScript is a Python interpreter designed specifically for microcontrollers, supporting a subset of common Python 3 syntax.
It's lighter, requiring only 32 KB of code space and 4 KB of RAM, which means it can run on STM32F103C8 (Blue Pill) or even STM32G030C8. This leaves valuable space for more material or larger buffer areas.
It's easier, running out of the box with no porting and configuration at all. It doesn't depend on an OS or file system, and has good support for popular Windows IDEs like Keil, IAR, and RT-Thread Studio. Of course, it also supports Linux GCC development platforms.
It's smarter, with a unique C module mechanism that allows you to generate bindings automatically by simply writing the API for the C module in Python. You don't need to deal with the headache of writing any macros or global tables manually. On the other hand, all C modules have sophisticated smart hints, even hinting at the types of your arguments.
PikaScript is an open source project on GitHub: https://github.com/pikasTech/pikascript
Why PikaScript + LVGL?#
PikaScript now supports the main features of LVGL8, and these APIs are fully compatible with MicroPython.
This means that you can continue to use already written code from MicroPython, and then use less code space and RAM.
The peak memory footprint of the ring animation demo is just 6.56 KB:
Memory usage showing 6.56 KB peak
Enjoy detailed code hints down to the parameter type for a better programming experience:
Code editor showing intelligent parameter hints
Use a more convenient IDE, such as VS-based simulation projects:
Visual Studio simulation project
LVGL Examples#
Here are some examples of LVGL that PikaScript can already run. They are mainly from the LVGL documentation examples.
Arc Widget#
import pika_lvgl as lv
import PikaStdLib
mem = PikaStdLib.MemChecker()
# Create an Arc
arc = lv.arc(lv.scr_act())
arc.set_end_angle(200)
arc.set_size(150, 150)
arc.center()
print('mem used max: %0.2f kB' % (mem.getMax()))
print('mem used now: %0.2f kB' % (mem.getNow()))
python
LVGL arc widget demo
Bar Widget#
import PikaStdLib
bar1 = lv.bar(lv.scr_act())
bar1.set_size(200, 20)
bar1.center()
bar1.set_value(70, lv.ANIM.OFF)
python
LVGL bar widget demo
Button Widget#
import PikaStdLib
def event_cb_1(evt):
    print('in evt1')
def event_cb_2(evt):
    print('in evt2')
btn1 = lv.btn(lv.scr_act())
btn1.align(lv.ALIGN.TOP_MID, 0, 10)
btn2 = lv.btn(lv.scr_act())
btn2.align(lv.ALIGN.TOP_MID, 0, 50)
btn1.add_event_cb(event_cb_1, lv.EVENT.CLICKED, 0)
btn2.add_event_cb(event_cb_2, lv.EVENT.CLICKED, 0)
python
LVGL button widget demo
Checkbox Widget#
import PikaStdLib
cb = lv.checkbox(lv.scr_act())
cb.set_text("Apple")
cb.align(lv.ALIGN.TOP_LEFT, 0 ,0)
cb.set_text("Banana")
cb.add_state(lv.STATE.CHECKED)
cb.align(lv.ALIGN.TOP_LEFT, 0 ,30)
cb.set_text("Lemon")
cb.add_state(lv.STATE.DISABLED)
cb.align(lv.ALIGN.TOP_LEFT, 0 ,60)
cb.add_state(lv.STATE.CHECKED | lv.STATE.DISABLED)
cb.set_text("Melon")
cb.align(lv.ALIGN.TOP_LEFT, 0 ,90)
python
LVGL checkbox widget demo
Drag and Drop#
from PikaStdLib import MemChecker
mem = MemChecker()
def drag_event_handler(e):
    obj = e.get_target()
    indev = lv.indev_get_act()
    vect = lv.point_t()
    indev.get_vect(vect)
    x = obj.get_x() + vect.x
    y = obj.get_y() + vect.y
    obj.set_pos(x, y)
    mem.now()
# Make an object draggable
obj = lv.obj(lv.scr_act())
obj.set_size(150, 100)
obj.add_event_cb(drag_event_handler, lv.EVENT.PRESSING, None)
label = lv.label(obj)
label.set_text("Drag me")
label.center()
python
LVGL drag and drop demo
Label Widget#
import PikaStdLib
label1 = lv.label(lv.scr_act())
LV_LABEL_LONG_WRAP = 0
label1.set_long_mode(LV_LABEL_LONG_WRAP)      # Break the long lines
# Enable re-coloring by commands in the text
label1.set_recolor(True)
label1.set_text("#0000ff Re-color# #ff00ff words# #ff0000 of a# label, \
align the lines to the center and  wrap long text automatically.")
# Set smaller width to make the lines wrap
label1.set_width(150)
label1.set_style_text_align(lv.ALIGN.CENTER, 0)
label1.align(lv.ALIGN.CENTER, 0, -40)
LV_LABEL_LONG_SCROLL_CIRCULAR = 3
label2 = lv.label(lv.scr_act())
label2.set_long_mode(LV_LABEL_LONG_SCROLL_CIRCULAR)  # Circular scroll
label2.set_width(150)
label2.set_text("It is a circularly scrolling text. ")
label2.align(lv.ALIGN.CENTER, 0, 40)
python
LVGL label widget demo
How Does It Work?#
PikaScript has a unique C module smart binding tool.
Just write the Python interface in pika_lvgl.pyi (.pyi is the Python interface file):
# pika_lvgl.pyi
class arc(lv_obj):
    def set_end_angle(self, angle: int): ...
    def set_bg_angles(self, start: int, end: int): ...
    def set_angles(self, start: int, end: int): ...
python
Then PikaScript's pre-compiler can automatically bind the following C functions, simply by naming the functions in the module_class_method format, without any additional work. All binding and registration is done automatically:
/* pika_lvgl_arc.c */
void pika_lvgl_arc_set_end_angle(PikaObj* self, int angle) {
    lv_obj_t* lv_obj = obj_getPtr(self, "lv_obj");
    lv_arc_set_end_angle(lv_obj, angle);
void pika_lvgl_arc_set_bg_angles(PikaObj *self, int start, int end){
    lv_arc_set_bg_angles(lv_obj, start, end);
void pika_lvgl_arc_set_angles(PikaObj *self, int start, int end){
    lv_arc_set_angles(lv_obj, start, end);
To use the module, just import pika_lvgl and the precompiler will automatically scan main.py and bind the pika_lvgl module:
$ ./rust-msc-latest-win10.exe
(pikascript) packages installed:
    pikascript-core==v1.10.0
    PikaStdLib==v1.10.0
    PikaStdDevice==v1.10.0
(pikascript) pika compiler:
  scaning main.py...
    binding pika_lvgl.pyi...
The precompiler is written in Rust, runs on Windows and Linux, and is completely open source.
In addition to binding C modules, the precompiler compiles Python scripts to bytecode on the PC, reducing the size of the script and increasing its speed.
Getting Started#
The simulation repo on Visual Studio is available at https://github.com/pikasTech/lv_pikascript
Lyon Lisboa
Lyon Lisboa
Community Contributor
Developer and LVGL community contributor focused on scripting language integrations for embedded graphics.
