LVGL v7.8.0: DMA2D Optimization and Arabic Text Support
Release of LVGL v7.8.0 with non-blocking DMA2D, enhanced Arabic text handling, KConfig support, and FPS measurement tools.
Gabor Kiss-VamosiGabor Kiss-Vamosi2 min read
LVGL v7.8.0 brings performance optimizations with non-blocking DMA2D support, improved Arabic text processing across multiple widgets, and new developer tools including KConfig integration and FPS monitoring.
  • Non-blocking DMA2D: Optimized graphics acceleration with asynchronous DMA2D operations for improved rendering performance
  • New built-in font: Added unscii-16 font for retro-style displays
  • KConfig integration: Build configuration support for embedded development workflows
  • FPS monitoring: New lv_refr_get_fps_avg() function to measure average refresh rate
Bugfixes and Improvements#
Internationalization#
  • Enhanced Arabic text support in button matrices
  • Fixed Arabic letter connections in text areas
  • Improved Arabic processing in dropdowns
  • Added Arabic support in value string properties
  • Fixed text processing to support re-processing already processed Arabic texts
Input Devices#
  • Fixed click propagation: disabled objects now allow parent elements to receive clicks
  • Improved button input type to recognize 1-cycle long presses
  • Fixed arc widget compatibility with encoder input
  • Enhanced slider left knob adjustment with encoder
Widgets and Rendering#
  • Fixed polygon drawing by joining adjacent points at the same coordinates
  • Corrected line meter invalidation when setting new values
  • Added missing invalidation when changing table cell types
  • Fixed reference to LV_DRAW_BUF_MAX_NUM in memory management
API Changes#
  • Renamed LV_ROLLER_MODE_INIFINITE to LV_ROLLER_MODE_INFINITE (typo fix)
This release focuses on stability and internationalization, with particular attention to right-to-left language support and input device handling improvements.
