LVGL v7.7.2 Released
Bugfix release for LVGL v7.7.2 with improvements to polygon drawing, arc dragging, and button matrix handling.
Gabor Kiss-VamosiGabor Kiss-Vamosi1 min read
This release focuses on bug fixes and stability improvements across several components.
  • draw_triangle: Fixed polygon/triangle drawing when the order of points is counter-clockwise
  • btnmatrix: Fixed setting the same map with modified pointers
  • arc: Fixed and improved arc dragging behavior
  • label: Repaired calculation logic for dot character that caused infinite loop
  • theme_material: Removed the bottom border from tabview header
  • imgbtn: Improved state guessing to find the closest available state with valid source
  • spinbox: Updated cursor position in lv_spinbox_set_step
