LVGL v7.4.0 Released
LVGL v7.4.0 introduces runtime font loading, style caching for improved performance, and enhanced arc controls with click-to-set value.
Gabor Kiss-VamosiGabor Kiss-Vamosi1 min read
The main new features of v7.4.0 are runtime font loading, style caching, and arc knob with value setting by click.
  • Runtime Font Loading: Add lv_font_load() function to load a lv_font_t object from a binary font file
  • Font Memory Management: Add lv_font_free() function to free memory allocated by lv_font_load()
  • Style Caching: Reduces access time of properties with default values for improved performance
  • Arc Click-to-Set: Arc widget now supports setting value by clicking directly on the arc
  • Arc Knob Part: Add LV_ARC_PART_KNOB to arc widgets, similar to the slider widget implementation
  • Enhanced Gesture Handling: Gestures are now sent even if the object was dragged. Users can check dragging state with lv_indev_is_dragging(lv_indev_act()) in the event function
  • Fix color bleeding on border drawing
  • Fix using LV_SCROLLBAR_UNHIDE after LV_SCROLLBAR_ON
  • Fix cropping of last column/row when an image is zoomed
  • Fix zooming and rotating mosaic images
  • Fix deleting tabview with LEFT/RIGHT tab position
  • Fix btnmatrix to not send event when CLICK_TRIG = true and the cursor slid from a pressed button
  • Fix roller width when selected text is larger than the normal text
