LVGL v7.2 Released with Screen Transitions and Theme Extensions
LVGL v7.2 introduces animated screen transitions, display background customization, enhanced chart functionality, and a new theme extension system.
Gabor Kiss-VamosiGabor Kiss-Vamosi2 min read
LVGL v7.2 is released with features like screen transition animations, easy theme extension support, and many other enhancements.
Screen Transitions#
Add screen transitions with lv_scr_load_anim() to create smooth animated transitions between screens.
Display Background Customization#
Add display background color, wallpaper, and opacity. Shown when the screen is transparent. Can be used with lv_disp_set_bg_opa(), lv_disp_set_bg_color(), and lv_disp_set_bg_image().
Calendar Enhancements#
Add LV_CALENDAR_WEEK_STARTS_MONDAY configuration option for localized calendar displays.
Chart Improvements#
New chart functions for advanced data visualization:
  • lv_chart_set_x_start_point() - Set the index of the x-axis start point in the data array
  • lv_chart_set_ext_array() - Set an external array of data points to use for the chart
  • lv_chart_set_point_id() - Set an individual point value in the chart series directly based on index
  • lv_chart_get_x_start_point() - Get the current index of the x-axis start point in the data array
  • lv_chart_get_point_id() - Get an individual point value in the chart series directly based on index
  • lv_chart_set_series_axis() - Assign series to primary or secondary axis
  • lv_chart_set_y_range() - Allow setting range of secondary y-axis
Add ext_buf_assigned bit field to lv_chart_series_t structure - it's true if external buffer is assigned to series.
Roller Customization#
Allow setting different font for the selected text in lv_roller widget.
Theme System Improvements#
  • Add theme->apply_cb to replace theme->apply_xcb to make it compatible with the MicroPython binding
  • Add lv_theme_set_base() to allow easy extension of built-in (or any) themes
Alignment Functions#
Add new alignment helper functions:
  • lv_obj_align_x() and lv_obj_align_y() - Align objects on a single axis
  • lv_obj_align_origo_x() and lv_obj_align_origo_y() - Align object origin on a single axis
  • Fix tileview navigation when not screen sized
  • Use 14px font by default for better compatibility with smaller displays
  • Fix linemeter conversion of current value to "level"
  • Fix drawing on right border
  • Set the cursor image non-clickable by default
  • Improve mono theme when used with keyboard or encoder
