LVGL v6.1 Released with Bidirectional Text Support
LVGL v6.1 introduces bidirectional text support, subpixel rendering, font compression, and a new color picker widget.
Gabor Kiss-VamosiGabor Kiss-Vamosi2 min read
Compatibility#
This is a minor release and remains fully compatible with v6.0. You can simply replace the lvgl folder with the new version.
You should update your lv_conf.h from lv_conf_templ.h to see the new configuration options.
Main New Features#
Bidirectional Support#
Add support for Right-to-Left and mixed writing directions. Learn more here.
Subpixel Rendering#
Make font rendering on lower resolution displays smoother. Learn more here.
Font Compression#
Store the bitmaps of fonts in a compressed way to reduce memory usage. Learn more here.
Higher Quality Fonts#
The algorithm of the font converter has been updated to produce better quality fonts.
New Symbols#
Additional symbols have been added to the built-in fonts. See all available symbols here.
Asserts in API Functions#
Add sanity checks to the API functions. They can be configured in lv_conf.h. You can use different configurations for development and production environments.
Color Picker Object#
A new color picker widget has been added. See it here.
Other Updates#
  • Added lv_list_set_layout to create horizontal lists
  • Added lv_slider_set_sym
  • Added lv_lmeter_set_angle #1262
  • Added lv_printf and lv_label_set_text_fmt for efficiently putting formatted text on labels
Credits#
  • @amirgon for bidirectional support
  • @puzrin for font compression and subpixel rendering
  • @paulpv and @AloyseTech for the color picker object type
  • @embeddedt for support, development, comments and reviews
