LVGL v5.3 - MicroPython Support and New Widgets
LVGL v5.3 brings MicroPython bindings, new object types including tileview and spinbox, plus official ESP32 and Zephyr integration.
Gabor Kiss-VamosiGabor Kiss-Vamosi4 min read
What Has Happened Since v5.2?#
LVGL Integrations#
LVGL's ecosystem expanded significantly with major platform integrations:
Community and Website Updates#
  • Blog - LVGL's Blog has been launched. It's for you to share your projects, tutorials, tips, and tricks. Read here how to add your post.
  • Forum - Our Forum is opened. Please use it for "how-to" questions and open GitHub issues for development related topics.
  • Documentation - The documentation is moved to a public repository where you can send pull requests to improve it. The documentation is available Online and Offline.
Some Metrics#
  • LVGL is getting more popular. According to the GitHub statistics LVGL is cloned every 10 minutes. (Not counting direct downloads from lvgl.com)
  • LVGL was a Top trending repository of GitHub. It was among the top 25 most popular repositories when compared across all languages, not only C.
MicroPython Support#
Thanks to @amirgon, you can now use LVGL with MicroPython (a Python implementation for embedded systems). Read more in this post. You can try it on Linux or with ESP32 using this ready-to-use repository.
New Objects#
  • lv_tileview - Container for smartwatch-like designs
  • lv_spinbox - Set numeric value with + and - buttons or keys
  • lv_table - Create lightweight tables
  • lv_canvas - Draw to a buffer and display it as an image
New Object Features#
Core Objects#
  • lv_obj - Add realign feature (save the last lv_obj_align data and re-apply)
  • lv_obj - Add lv_obj_align_origo to align the center of the object (works with realign)
Charts#
  • lv_chart - LV_CHART_TYPE_VERTICAL_LINE when the point count equals the chart width to draw only vertical lines
  • lv_chart - Add LV_CHART_POINT_DEF special value to not draw a point
Input Widgets#
  • lv_sw - Animated move (lv_sw_set_anim_time(), lv_sw_on/off_anim())
  • lv_btnm - Add lv_btnm_get_pressed()
  • lv_btnm - Add recolor feature with lv_btnm_set_recolor
  • lv_ta - Support LV_GROUP_KEY_BACKSPACE
  • lv_ddlist - Add down arrow symbol option with lv_ddlist_set_draw_arrow
  • lv_ddlist - Add ability to set label alignment
List and Scrollable Objects#
  • lv_list - Remember the last selected button (only if the list is in a group)
  • lv_list - Allow single button selection mode
  • lv_list, lv_ta, lv_page - Scroll propagation feature to scroll the parent on "overscrolling"
  • lv_list, lv_ta, lv_page - Edge flash effect to show circle on the edge on "overscrolling"
Other Widgets#
  • lv_preload - Add lv_preload_set_animation_type() and LV_PRELOAD_TYPE_FILLSPIN_ARC
  • lv_imgbtn - Add tiled option to set width dynamically by repeating the middle part
  • lv_calendar - Add lv_calendar_get_pressed_date
  • lv_tabview - Add lv_tabview_set_hidden to hide tab buttons
New Other Features#
System Features#
  • lv_lang - Multi-language interface to change UI's language at runtime
  • lv_group - Add LV_GROUP_KEY_BACKSPACE
  • lv_anim - Add overshoot and bounce path
  • lv_anim - Add lv_anim_count_running
  • lv_indev - Add lv_indev_set_feedback to add callback when something happened with an object
  • lv_vdb - Add true double buffering feature to work with only frame buffer address swapping
  • lv_style - Add LV_BORDER_INTERNAL to remove the borders on the edges
  • lv_porting - Add display, input device, file system porting skeleton functions
Plans for v6.0#
The next major version will focus on:
  • Multi-display support
  • Runtime screen configuration (instead of hard-coded defines)
  • Generic action handling (lv_obj will have an action)
  • Better GPU handling
  • Image rotation
  • Better internationalization support (i18n)
You can track the progress in this issue.
