LVGL Pro Project Structure and Naming Guide
How to organize assets, name widgets, and write reusable XML in the LVGL Pro Editor.
Felix BiegoFelix Biego4 min read
The LVGL Pro Editor is a powerful tool for embedded UI development, but as any seasoned developer knows, a powerful tool is only as good as the workflow behind it. Without a solid structure, a small project can quickly turn into a maintenance nightmare of messy XML and conflicting asset names. To help you build cleaner, more professional interfaces, we've compiled the ultimate guide to LVGL Pro best practices.
1. Naming Conventions#
Consistency is key. When your project grows to dozens of screens and hundreds of assets, clear naming ensures you aren't hunting for files.
Project & Asset Naming#
  • Assets: Always use descriptive prefixes.
    • Images: icon_home, img_background
    • Fonts: Use the format font_size_weight (e.g., font_16_bold). This is vital when managing long lists of varying sizes and formats.
Project Naming
Never name your project lvgl. This causes namespace conflicts with the library itself. Choose a unique name specific to your product.
Styles & Subjects#
Prefixing allows for better filtering in the editor and clearer code generation.
  • Styles: Use style_. If you support multiple themes, include the theme name: style_dark_button or style_light_button.
  • Subjects: Use subject_ (e.g., subject_settings).
Widgets#
To distinguish components from widgets, use the wd_ prefix:
  • wd_menu, wd_statusbar, wd_clock.
2. Organized Resource Management#
Mixing raw source files with generated code is a recipe for accidental deletions.
Recommended Structure: Keep your raw .png files in a dedicated subfolder within your images directory.
images
  • icon_home_20dp.cGenerated output
  • img_background.c
Tip
Always include the size (e.g., _20dp) in the filename for icons that exist in multiple resolutions.
3. Architecture: Screens, Components, and Widgets#
Don't dump everything into the root directory. Use the Add New Component / Widget / Screen workflow. This automatically organizes files into subfolders, keeping the project tree navigable.
Add New Screen button
Use the Add New workflow to keep your project organized
The "Golden Rule" of Generated Files#
  • Need a change? Modify the source XML.
  • Need custom behavior? Use the provided API, external logic hooks or custom widgets.
Do Not Edit Generated Files
Any manual changes made to the generated C files will be lost the moment you hit "Export Code" in the editor.
4. Writing Clean, Reusable XML#
The way you define your UI in XML determines how flexible your interface is.
Avoid Inline Styles#
Inline styles make your XML bloated and hard to update. Instead, define reusable styles.
Inline Styles
<lv_obj style_bg_color="0x000000" style_bg_opa="255" />
xml
Reusable Styles
<styles>
   <style name="style_main_bg" bg_color="0x000000" bg_opa="255" />
</styles>
<lv_obj>
   <style name="style_main_bg" />
</lv_obj>
xml
Smart Component Sizing#
To make components truly reusable, avoid "double-locking" sizes. If both the container and the child have fixed widths, the component becomes rigid.
  • Bad: Component root is content width, Child is 420px. (Hard to resize).
  • Good: Component root is 420px, Child is 100%. (Child scales with the component).
5. Component API & State Safety#
When building custom components, be careful not to "clobber" internal editor properties.
  • Document your API: Use the help property so other team members know what a property does:
<api name="text" type="string" help="Sets the label text of the header" />
xml
  • Keep Defaults Clean: Avoid overriding default flags (like checked="true") on the root of a component. It's better to set these specific states when you actually place the component onto a screen.
Warning
Do not use name as an API property. It often conflicts with Editor-specific logic.
Learn More#
For a deeper dive into everything covered in this guide, check out the official LVGL Pro documentation.
DocsXMLOverview
Read documentation
Learn more about XML-based UI definition, component architecture, and code generation in the full LVGL Pro documentation.
Summary#
By following these patterns (consistent prefixing, separating raw assets, and using reusable styles) you ensure that your LVGL Pro project remains maintainable for years to come.
Felix Biego
Felix Biego
Embedded UI Developer - LVGL Services
Embedded UI Developer at LVGL Services, implementing client UI designs and enabling teams to build production-ready interfaces with LVGL Pro.
