RZ/G Family
Build and run the ready-to-use LVGL projects of the Linux-capable RZ/G2L, RZ/G2UL, RZ/G3E, and RZ/G3L evaluation kits with their cross-compiler SDKs.
Edit on GitHub
Supported boards in the RZ/G Family:
  • RZ/G2L-EVKIT
  • RZ/G2UL-EVKIT
  • RZ/G3E-EVKIT
  • RZ/G3L-EVKIT
G2L and G2UL
The RZ/G2L and RZ/G2UL are MPUs with support for running Linux. Projects are built for them using a cross-compiler CLI toolchain SDK in a Linux PC environment (WSL, Docker, etc. can be used on Windows).
The G2L has a Wayland desktop and the project appears as a Wayland window. The G2UL does not have a desktop so the project is fullscreen and uses the fbdev driver.
The SDK currently uses LVGL v8.3 so this project uses this version to mirror the SDK version, even though LVGL is statically linked. You may try using newer versions of LVGL. See the v8-to-v9 Migration Guide for things you will need to address.
Prefer Ubuntu on the G2L?
Canonical publishes Ubuntu images for the RZ/G2L, and LVGL publishes prebuilt Ubuntu packages. That path needs no cross-compiler and gives you current LVGL with GPU-accelerated DRM/EGL rendering: see LVGL on the RZ/G2L with Ubuntu.
Run the Project
Clone the project: Clone the ready-to-use repository for your selected board:
git clone https://github.com/lvgl/lv_port_renesas_rz-g2l-evkit --recurse-submodules
Downloading the .zip from GitHub doesn't work as it doesn't download the submodules.
Build and upload: Follow the instructions in the project's README.md to obtain the SD Card image and toolchain installer, build, and upload the project to the board.
Free up the display: Stop any automatically started demos. On the G2UL run systemctl stop demo-launcher in the terminal.
Run the project:
./lvgl_demo_benchmark
Modify the Project
Open a demo
The entry point is contained in src/main.c.
You can disable the LVGL demos (lv_demo_benchmark()) (or just comment them out) and call some lv_example_...() functions, or add your own custom code.
Configuration
Edit lv_conf.h and lv_drv_conf.h to configure LVGL. The board image contains LVGL and lv_drivers as dynamically linkable libraries. This project builds LVGL statically for customizability and to port the LVGL v9 benchmark from LVGL v8.3.
G3E
The RZ/G3E is a high-performance quad-core MPU. Projects are built for it using an SDK that was generated with Yocto. You can customize a Yocto image+SDK or use the pre-built ones. The SDK is intended for a Linux PC environment (WSL, Docker, etc. can be used on Windows).
The G3E has a Wayland desktop but it should be stopped with systemctl stop weston before running the default project, since that runs in fullscreen using the OpenGL EGL+DRM driver.
LVGL is not included in the SDK so you should build whichever version you need. Later versions of LVGL include the optimal OpenGL driver.
Run the Project
Clone the project: Clone the ready-to-use repository:
git clone https://github.com/lvgl/lv_port_renesas_rz-g3e-evkit --recurse-submodules
Build and upload: Follow the instructions in the project's README.md to flash the board bootloader and obtain the Yocto SD Card image and SDK (pre-built or custom-built), build, and upload the project to the board.
Free up the display: Stop the Wayland desktop if using the OpenGL, DRM, or fbdev drivers. Run systemctl stop weston in the terminal.
Run the project:
./lvglsim
Modify the Project
Open a demo
The entry point is contained in lv_port_linux/src/main.c.
Configuration
Edit lv_conf.h to configure LVGL. You can edit lv_conf.defaults — a sparse version of lv_conf.h which you can use to regenerate lv_conf.h by running
python3 lv_port_linux/lvgl/scripts/generate_lv_conf.py
G3L
The RZ/G3L is a quad-core Cortex-A55 MPU with an Arm Mali GPU, on a SMARC 2.1.1 module paired with the Common Carrier Board II. Unlike the other boards in this family, it needs no Yocto build and no bootloader flashing: Renesas' RZ/G HMI SDK ships a prebuilt bootable image and a matching cross-compilation toolchain in a single download, and the board boots straight from the microSD card.
The project lives in the lv_port_linux repository rather than a board-specific one, under boards/renesas_rz-g3l-evkit, with two ready-made Kconfig defconfigs: sw.defconfig for NEON software rendering over the Wayland DMABUF backend, and nanovg.defconfig for GPU rendering through NanoVG on OpenGL ES, which also enables glTF for 3D content.
The image boots into a Weston desktop, so the project runs as a Wayland client by default. The DRM driver is also compiled in and can be used by stopping weston.
See the board's README for the full guide.
Support
On this page
