# RZ/A Family (/integration/chip_vendors/renesas/rza_family)
Supported boards in the RZ/A Family:
* **RZ/A3M**
Run the Project [#run-the-project]
<Steps>
  <Step>
    **Install e² studio**: The RZ/A boards are MPUs with a focus on bare metal and RTOS applications.
    Projects are built for them using the e² studio IDE, available for Windows, Mac, and Linux.
  </Step>
  <Step>
    **Clone the project**: Clone the ready-to-use repository for your board:
    ```bash title="bash" lineNumbers=1
    git clone https://github.com/lvgl/lv_port_renesas-ek-rz_a3m --recurse-submodules
    Downloading the `.zip` from GitHub doesn't work as it doesn't download the submodules.
  </Step>
  <Step>
    **Build and flash**: Follow the instructions in the project's `README.md` to build and flash
    the project to the board.
  </Step>
</Steps>
Modify the Project [#modify-the-project]
Open a demo [#open-a-demo]
The entry point is contained in `src/LVGL_thread_entry.c`.
You can disable the LVGL demos (`lv_demo_benchmark()`) (or just comment them out)
and call some `lv_example_...()` functions, or add your own custom code.
Configuration [#configuration]
Edit `lv_conf.h` to configure LVGL.
It will automatically run any demo that is enabled in `lv_conf.h`. You can see
`lv_conf.defaults` for a summary of the configs which have been changed from the defaults.
Support [#support]
