# Built-in Drivers (/integration/chip_vendors/renesas/built_in_drivers)
[Renesas](https://www.renesas.com/) is an official partner of LVGL. Therefore, LVGL contains built-in support for
[Dave2D](https://www.renesas.com/document/mas/tes-dave2d-driver-documentation) (the GPU of Renesas) and we also maintain
ready-to-use Renesas projects.
Dave2D [#dave2d]
Dave2D is capable of accelerating most of the drawing operations of LVGL:
* Rectangle drawing, even with gradients
* Image drawing, scaling, and rotation
* Letter drawing
* Triangle drawing
* Line drawing
As Dave2D works in the background, the CPU is free for other tasks. In practice, during rendering, Dave2D can reduce the CPU usage by
half to one-third, depending on the application.
More info can be found at the [driver's page](/integration/chip_vendors/renesas/dave2d_gpu).
GLCDC [#glcdc]
GLCDC is a multi-stage graphics output peripheral available in several Renesas MCUs. It is able to drive LCD panels via a highly
configurable RGB interface.
More info can be found at the [driver's page](/integration/chip_vendors/renesas/glcdc).
MPU Drivers [#mpu-drivers]
Renesas MPUs (e.g. the RZ/G family) can use these LVGL MPU drivers.
Wayland [#wayland]
Use of the Wayland driver is supported on boards with a Wayland desktop, a.k.a. a Wayland compositor.
fbdev [#fbdev]
The LVGL `fbdev` (frame buffer) display driver can almost always be used.
OpenGL [#opengl]
The constantly evolving OpenGL driver in LVGL has proven to be the most performant driver
in at least one case and can be used wherever the prerequisites are satisfied.
